at what point do u need better injectors?
Whether you need bigger injectors or not is determined by injector duty cycle. You don't want your injector duty cycle maxing out ir coming close to maxing out. Anything over 80% and you should consider bigger flowing injectors.
Your tuner will be able to tell you what the duty cycle is at. A lot of times it's better to upgrade to bigger injectors before getting tuned, otherwise your tuner may have to charge you again to get it re tuned
well right now i plan on going with an ls6 intake and some ported 243 heads with either of those cams would those mods justify getting bigger injectors with either of those cams?
Grade
I hit 452 by the skin of my teeth. I even had 42#'ers on the car when we swapped on the dyno, and got the gracious news that one was dead. It sucked, and we tuned what we could "safely"
I'm obviously a little bias but I would definitely go with the v3. The cam paired up well with my 243's and actually has some street manners!
https://ls1tech.com/forums/pcm-diagn...injectors.html
Cam only and I was at 105 duty cycles at 5800 rpms. I got racetronic 42lb injectors. My tuner let me put them in real quik when the car was sitting on the dyno.
