cruise control delete help ! ?
Old Oct 17, 2012 | 04:15 PM
ZeroC's Avatar
Default cruise control delete help ! ?
99 z28 auto
in front of battery has cruise control box with 3 cables going to it ...2 to the firewall and one to the tb..
i want to take it out since i never use the cruise control ever !! ( and to tidy engine bay )
what do i need to do ..please advise
Old Oct 17, 2012 | 05:15 PM
Orange Juice's Avatar
You are going to need a single throttle cable. I picked up one in the for sale section, do a search.
Old Oct 18, 2012 | 03:39 PM
rabbit320's Avatar
if yr interested in selling / trading the cruise control leme know, i have the box just need the wires i think...
Old Oct 18, 2012 | 04:26 PM
01ssreda4's Avatar
You need a 98-99 non-TCS, non-cruise throttle cable. Remove everything and replace the new cable from pedal to TB.
Old Oct 18, 2012 | 04:27 PM
3rdgen92maro's Avatar
I did this a few months ago. I bought a throttle cable for a non cruise control car from the local Gm dealer. Paid around 35 bucks for it.
Old Oct 18, 2012 | 08:38 PM
ZeroC's Avatar
awesome replies
when i take this stuff out will i lose my tcs / ASR???
Old Oct 19, 2012 | 12:17 AM
01ssreda4's Avatar
Pretty sure that's separate. You can delete on or the other or both. My way above deletes both because I think the TCS is useless anyway.
Old May 24, 2013 | 03:42 PM
badinfluence77's Avatar
I apologize for bringing this back from the dead,but from my search results,this had the most relevant information.
I have been cleaning up my engine bay by deleting the stuff I never use,and I'm considering deleting the cruise control,but I kinda want to keep the traction control.
If I use the single throttle cable method,can I be rid of the black box,or does the traction control operate through that as well?
Old May 24, 2013 | 11:21 PM
01ssreda4's Avatar
Traction control is near the battery, and cruise is down by the driver suspension. Separate cable for each. TCS has two cables: Pedal>TCS unit>Engine. Cruise should only have a single cable from the module to the engine. Crap my memory is fogging, so maybe someone can confirm.
Old May 25, 2013 | 06:54 AM
I thought it was on the passenger side,that's where the cable from the tb leads to. Altogether,3 wires/cables are attached to that box.
Old May 29, 2013 | 03:46 PM
VandykeT/A's Avatar
On my 2000 traction control and cruise all T together into the box next to the battery. My 02 didn't come with tcs so I have two completely different cables. Unless they're a way to modify the box at the battery to remove the cruise cable the only way I see of doing it is to remove both and go with a single cable.
Old May 29, 2013 | 04:33 PM
01ssreda4's Avatar
^^Yeah my TCS had 3 cables as well. Non-TCS cars had the cruise cable going straight to the TB I believe.
