Budget catch can?
Old Oct 30, 2012 | 06:27 PM
sjsingle1's Avatar
Originally Posted by DarkblueTA
How about an air seperator from the air compressor section at Lowes or Home Depot? It would be cheap and worked fine for me on my 98.
i got one..........but the fitting at the bottom was not sealing and caused a vacuum leak
Old Oct 30, 2012 | 09:04 PM
TyCZ28's Avatar
seriouslyyy...... JUST BUY A $20 one from ebay. dont put that redneck engineered thing on your car!
this cost me $20 plus $1.95 for a PCV valve at O'Reilly and like 3 feet of hose...
Old Oct 31, 2012 | 09:54 AM
cknoma2005's Avatar
Or you can be creative and make a better\cheaper version. Besides driving a raw high horse-powered car, engineering\ improving the way my car functions is the most fun.
Old Nov 1, 2012 | 09:50 AM
thunderstruck507's Avatar
The one on ebay I saw was more of an overflow can than a filtered catch can and the sight tube looks like ****. Once this is painted black and installed where I intend to you will be hard pressed to even see it and if you do it will look like the high dollar JLT one the mustang guys use.
I'm not using wooden head bolts here...it's a damn catch can. If it doesn't work it will take all of 30 seconds to pull it off and go back to factory.
Old Nov 1, 2012 | 11:03 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Damn right. We went to oak studs a while back!
Sorry man. That comment was funny as hell
Old Nov 1, 2012 | 02:19 PM
joecar's Avatar
Originally Posted by dr_whigham
Another little project idea I used to have way back when.... If you have deleted the AC (FBody specific, this is) you can do this exact thing with the accumulator canister. Has it's own bracket and all... pretty trick if you ask me.
That's a great idea... stealthy too.
Old Nov 1, 2012 | 02:23 PM
joecar's Avatar
lol, wooden head bolts and billet tp axles... reminds me of the best flat washer.
Old Nov 26, 2012 | 08:58 AM
UPDATE: ~300 mile round trip to the track and a day of racing, checked it the next day and I had about half a teaspoon of oil in the bottom of the cap.
Now that I know it works, I will be painting it black and installing it near the firewall behind the drivers side head. Out of sight and out of mind for the most part and less oil getting in my intake.
Old Nov 26, 2012 | 05:58 PM
2nd Gen Fl 'bird's Avatar
Bead blast it for texture and paint it. No one will know what the hell they're looking at.
Old Nov 26, 2012 | 06:13 PM
davidws6's Avatar
Glad it worked out for ya. I did the A/C Accumulator for a catch can. Stuffed it under the bumper outta sight. Works great and have maybe $15 in fittings.
Old Nov 26, 2012 | 07:41 PM
RJDio's Avatar
I've used the $20 one from Ebay (this is old pic, I've since removed the clear plastic tube and capped the holes so it won't look ricey) and mounted on head using a fence pole part from home depot - turned out okay. It works great, I empty it about once a month
Old Nov 26, 2012 | 10:37 PM
  #32
99Bluz28's Avatar
So, how does the intake look inside...?
Old Nov 27, 2012 | 08:54 AM
  #33
The intake hasn't been removed and cleaned since it went on several years ago. I had it off for the head/cam swap but was too busy chasing my tail on every other little thing to worry about it. Had a light coat of oil, just enough to make everything glossy. I blew it out with an air hose and stuck it back on.
The car used 1 qt every 2500 miles or so. I consider that pretty good since if I'm driving the car, it is getting run hard fairly often.
The car does smell less like burning oil on heavy decel already. Should only get better as it continues to dry out more.
I might eventually get one of the ebay ones and modify it to remove the site tube and add some filter media like my current steel wool inside. Really didn't want to spend any more than I had to until I could test to see if it was even worthwhile.
I didn't even cut my hose to fit this one, just connected it to the hose that runs to the intake and added another piece I had laying around to the other side.
