New Holley LS Mini Ram Intake
#63
I saw that it's on Summit's site. http://www.summitracing.com/parts/hly-300-126
Is it worth taking a risk on, who knows. I'm running 15psi of boost, so I'm sure my original FAST 90 is leaking like a bitch under boost, so who knows, I may try it.
#64
1 Post
Some are known to crack under certain amounts of boost. I don't have any first hand knowledge with that but have seen it happen to others before...
#68
1 Post
Not necessarily. He said the tallest part of the intake is 10.1in, and that is the front by the way it slopes up. If the FAST is 6in and has right around 3in of clearance, there is a chance that if the Holley slopes down enough it will fit with some massaging to the cowl (not cutting)
#69
Massaging, That would mess w/ the cowl plastic / hood seal and maybe hood closing. But I think w/ my hood closed I can squish the seal .5", and maybe some heat applied to the plastic to soften it up to comform around a shape, this may give another .5" of room w/ the possibility of another .5" w/ a k-member drop.... or somebody make a fiberglass cowl / wiper piece w/ the clearance molded in so you can still use a hood seal? And possibly you would have to cut that part of the hood brace out to go over the new "clearance hump so you can still run a hood seal for those of us w/ no garage... I apologize if these ideas sound crazy, it's sleepiness talking.
#71
I havent had a customer install one of these yet so I couldnt be sure of fitment on F-Bodies right now. Does this picture help?
The 10.1" dimension I got was in the dead center of the intake. Heres a Holleyt Drawing that shows the dimensions at each end.
#73
I take back my previous ideas because while looking through some pics I had when I was chasing a leak and removed the cowl plastic pieces, the pics I found just told me flat out "no deal"
#76
#77
Hopefully someone will install one. I really want to run one of the Holley intakes on my turbo set up, but I dont want to delete my wipers. I guess it is something to think about.
It would also be nice to see comparisons of the Holley Hi-Ram vs the Mini-Ram, just to see if you are giving anything up to run the Mini-Ram.
#79
1 Post
Well if this intake ends up being a bust, not all hope is lost. Check out this thread...
https://ls1tech.com/forums/general-l...duct-poll.html
