New Holley LS Mini Ram Intake
Old Jun 25, 2013 | 06:21 AM
  #121
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by hawksthirdgen
Well I never drive it in the rain cause of the rear mount turbo (hate the sock condom) plus we use k-member spacers on all the F-Body Maggie kits we do so that was no issue. I guess I wanted to do it cause no one has in an F-Body plus it does look sick! I get compliments on it everywhere...
Please don't think that I don't love the way it looks, and the performance is definitely a step above the LS6 intake at every rpm. For some reason I was thinking you did the swap from a FAST 92/102 to this and had the gains.
My only reason for windsheild wipers is just to pass inspection. I actually remove my wiper arms most of the year, then put them back on for inspection.
How bad was the cuts in the cowl that you had to make? More or less compared to the Maggie kit?
Old Jun 25, 2013 | 06:32 AM
  #122
grimspyder's Avatar
Looks Great and i like that its different, Just seems like its a lot of work for a DD.
Old Jun 25, 2013 | 06:34 AM
  #123
grimspyder's Avatar
Well, not really a lot of work, I guess its just the wiper issue. You need Wipers here in FL. Bright and Sunny one second. Next Second Torrential Down Pour!!
Old Jun 25, 2013 | 07:28 AM
  #124
LS1-450's Avatar
Originally Posted by The Alchemist
I've got to be honest, I'm not hugely impressed. Is there a gain, hell yeah, and through the entire rpm range, but I wonder how a FAST 102mm would have compared.
It destroys the FAST in the most important category. It's not over priced.
Will admit that NA the FAST probably wins. Won't know for sure 'till NA numbers on the mini-ram air start showing up.
Old Jun 25, 2013 | 09:05 AM
  #125
UNDER PRESSURE MOD
Very true, it's priced a good $400 less.
Old Oct 14, 2013 | 12:11 AM
  #126
Bucks68's Avatar
I am thinking of using this intake on the '02 5.3L w/GM hot cam in my '68 C10. The one thing I can't find is what injectors work with the manifold and fuel rails. I'd like to order it all at the same time, but can't find any installations with part numbers. Any help?
Old Oct 14, 2013 | 01:26 PM
  #127
badazz81z28's Avatar
More like $325 or so. If it takes your wipers out and some massaging with no real gains over the FAST intakes, the $325 is worth the expense to me. I don't suspect the Holley to perform better and it would be good to see a real comparison. We need the folks at Vengeance, Texas Speed, Tick, Mamo to do some testing for us.
Old Jan 23, 2014 | 07:41 PM
  #128
GrannySShifting's Avatar
A few more pics when installing and also the dyno sheets.
You have dyno sheet comparison SAE corrected? uncorrected is meaningless comparison, 40hp swings due to temps we see all the time in uncorrected numbers
Old Aug 13, 2014 | 05:11 PM
  #129
Spectre86's Avatar
Q
Had to use 1/2" k-member spacers and cut the cowl and remove the wipers. Made 50 extra HP over an LS6 intake at 4000rpm!
also wondering on this. I know this is old. But cant seem to find any pics or current threads of the mini ram in 4th gens.
