Who uses ARP header studs
Old Oct 30, 2012 | 11:35 PM
2nasty's Avatar
Default Who uses ARP header studs
I'm about to install kooks 1 7/8 headers (with kooks true duals)and would like to use the arp header studs, So I don't have to work about breaking bolts or cross threading from pulling off and on. My question is what part number. I have searched but read they make a few different sizes. Texas speed sells 434-1301 but want to get the correct ones. Also is there enough room on a 02 t/a to install the studs and slide the headers on them or to tight to do that and have to hold the header and scew the studs in with the header in place?
Old Oct 31, 2012 | 12:19 AM
Decadence75's Avatar
I have the ones from TSP and they work great. The only time I've had to remove a few of them was when I took the heads off.
https://www.texas-speed.com/p-429-arp-header-studs.aspx
Old Nov 1, 2012 | 01:37 AM
2nasty's Avatar
Ok thanks. Anyone else?
Old Nov 1, 2012 | 10:01 AM
Ferocity02's Avatar
I used stainless ones from eBay, they are holding up great so far, $30. I couldn't justify spending that much on the ARP ones when they will only see 18 ft-lbs.
Old Nov 1, 2012 | 10:23 AM
03Sssnake's Avatar
I use them, makes it a lot easier to hang your headers if you are doing the job solo!
Old Jan 19, 2013 | 06:43 AM
Raptor_WS6's Avatar
do you have a part number or the ebay seller
i only found some for 52 bux on ebay
Old Jan 19, 2013 | 08:58 AM
01ssreda4's Avatar
After I got sick of the stockers, and not wanting the Stage 8 with those goofy *** clips, I went with Percy's split lock. Pain in the *** to manage those little allen heads and the bolts rust. $60 down the drain IMO. I am now running a stainless bolt from an ebay seller. They were a nice graded bolt. Looks like the guy bought in bulk and just bagged em up in sets. Been super happy with them and they were like 15-20 bucks. $100 is too much to spend for studs unless your headers are gonna be R+R a ton of times.
Old Jan 20, 2013 | 04:19 PM
Ferocity02's Avatar
They seller isn't selling them anymore, or selling anything for that matter: http://myworld.ebay.com/alper-motors...E:L:OU:US:1181
Old Jan 22, 2013 | 10:38 AM
cbrodine's Avatar
Yes they are, I just found this today...
http://www.ebay.com/itm/LS1-Ls6-Ls3-...f15019&vxp=mtr
Old Feb 10, 2013 | 01:11 PM
splitfinger09's Avatar
