Can running 1 cat damage engine?
Old Nov 4, 2012 | 09:20 PM
jthunderz28's Avatar
Default Can running 1 cat damage engine?
Had 1 of my catalytic converters badly damaged the other night.
Currently running straight pipe on one side and kept the high flow cat on the other side. I had a friend just weld in straight pipe in place of the cat.
Everything still merges into the I pipe via the Y pipe.
My car has a mild cam(222/226) and headers and had a dyno tune.
Is running 1 cat bad for the motor?
Old Nov 4, 2012 | 11:39 PM
70 views and not one response? Should this be in a different section?
Old Nov 4, 2012 | 11:55 PM
omgitsmikeyc's Avatar
To put simply: no. You will suffer some back pressure loss, but less pressure can't be a bad thing. The enhanced answer means your sensors will start going wonky as you will not be reading the CO2 correctly at your oxygen sensors. To correct this, tune them out. If you can get away without one cat, you can get away with two and should go full straight pipe. The other option is go to a pick it yourself junkyard and cut one off to get you by, or buy a new one....
Old Nov 5, 2012 | 12:09 AM
Thanks man, i just wasn't sure if it would mess up the tune in terms of timing, a/f ratio etc...i'm totally clueless when it comes to the tuning aspects of these cars.
Old Nov 5, 2012 | 12:14 AM
Redbull87's Avatar
Wont mess things up...it will affect the tune if not corrected though.Expect an o2 code shortly and less gas mileage having odd readings now on one bank.Will it affect power..hardly noticeable if any.
