Stock Injectors?
Old Nov 16, 2012 | 09:29 PM
S10xGN's Avatar
Default Stock Injectors?
Are the '99 Camaro stock injectors (gray body) worth keeping? What do they flow and if I run an adjustable regulator and jack up the rail pressure, what HP will they support?
Old Nov 17, 2012 | 12:09 AM
bww3588's Avatar
Increasing rail pressure on stock injectors is only good if your injectors aren't maxed out. Stock 99 injectors are 26lb/hr @ 58 psi. They will support about 400 at the wheels before duty cycle exceeds 85%.
Depending on your setup, I would look into larger injectors.
Old Nov 17, 2012 | 12:17 AM
mezzyshreder's Avatar
I increased the injector size once I began pushing over 400 hp to the crank. Made a difference
Old Nov 18, 2012 | 12:27 AM
trans_am7935's Avatar
i have seen guys have problems with cam only cars making 400whp with stock injectors, but have seen others do fine. it is better to change them, as a lean motor is an exploded motor
Old Nov 18, 2012 | 01:23 AM
bww3588's Avatar
Lean is mean...
On a serious note, always best to err on the side of caution and upgrade them.
Old Nov 18, 2012 | 07:32 PM
S10xGN's Avatar
OK, looks like some 42.5's are on the list...
Old Nov 19, 2012 | 01:53 PM
MikeWS6's Avatar
I am still running the stock injectors. My car put down 370 on a mustang dyno so that might be close to 400 on a dyno jet. I havent had any problems but I am considering changing them.
