bad balancer destroy accessory
Old Nov 16, 2012 | 09:49 PM
3rdCoastPowerSports's Avatar
Default bad balancer destroy accessory
I would just like to clear this up. Can a Wobbling harmonic balancer destroy accessory's. i.e cause a water pump bearing to get eaten up, cause power steering pump bearing to make noise.
Old Nov 18, 2012 | 08:40 PM
marc.madmax's Avatar
Don't believe so. but I put an aftermarket on to replace and blew it out. believe caused by the radical cam and a bent snout. the bent crank was the cause not the balancer. the twinkie that changed the cam (not me) reused the bolt and spun out. Hello engine rebuild. You have a tensioner that should handle the slack and the tension unless you have belts that are too tight. That was my story. did blow the bearing in the water pump but I don't have the steering pump problem.
Old Nov 19, 2012 | 10:27 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The only thing that connects the balancer and other accessories is the belt, but wobbling would not be transferred in a harmful manner that I could imagine.
It can and and will destroy your engine though!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
