True Duals PLUS Cat-Back. Which Cat-Back?
I like this setup because with other cutout setups i have seen the pipe for the cutout just comes off the main pipe at like a 45 degree angle allowing a lot of the flow and sound to continue to travel out through the tail pipes. In this setup the cutouts open and it's a straight shot out for the flow. Most should bypass the over the axle pipe. This setup also benefits from being able to clear the axle easily and being able to hang a stock style cat-back on stock hangers!
Planning on running single chamber flows where the bullets are in this setup. The texas speed duals have a little space between pipes so hopefully I could fit 2 single chambers side by side, then run the pipes together in time to hit the combination pipe.
What cat-back would you run behind pacesetter lt's, tsp ORX, and single chambers for when the cut-outs are closed? Still want to have a little mean sound but mostly want it to be quiet for early morning/late night courtesy.
I would run 2 3" e-cutouts where the caps are in this picture so I don't have to get under the car haha.
Can you think of any advantages of this setup over one with traditional y-shaped cutouts right after the bullets and then having the two pipes just run together and go over the axle?
The car it came off of was bone stock besides the longtubes/exhaust and a LS6 intake. With the caps off, it was loud but had good tone and rumble, nowhere near as obnoxious as a Loudmouth. Closed, it was factory quiet. No ****, it tucked so well, we had no clue it was true duals til the car was in the air
