Want to run single muffler dumped off Magnaflow Y???
What are my muffler options? Know bullet style fits but might want a more quite option. Also do I need to mount muffler to underbody some where?
dont know how quiet your looking to go, bullet is pretty much your only option for a dumped muffler that i know of. I am running a dumped moroso spiralflow, with a bracket welded to back pass seatbelt bolt. Any good shop should be able to figure out a bracket though, depending on how far back your looking to go.
im in the same situation and i do have a dynomax bullet and it is way to loud for me. So for me too im looking for another muffler but i did see on summit they had something similiar but it said it was designed for diesel so would that make a big difference on a gasoline engine
Either a Magnaflow 12867 (5"dia.,14" case L, $100) or a Borla XR1 40085 (5"dia., 15" case L, $130). You'll need to clearance the underbody in the I-pipe area around the 9-11 O-clock area if you want to tuck it up higher. I used the Magnaflow in my previous dumped set-up and it was surprisingly quiet; for a dumped exhaust.
