New intake
Old Dec 17, 2012 | 12:24 PM
1998silverbird's Avatar
Default New intake
Wonderring what everyone does when they install a 100mm TB.. Right now I have a SLP lid, Bellow, and SLP maf. Should I keep all that and add a 85mm to 100mm tube, Should I add 100mm maf ends to the Maf or should I add a 100mm MAF and 104mm lid? I was hoping to keep the SLP stuff on for the time being but if I cant I will switch over to the bigger items..
Old Dec 17, 2012 | 10:04 PM
Blk98Vert's Avatar
I would absolutely run the 104/100 combo
Old Dec 17, 2012 | 10:27 PM
Mike Morris's Avatar
Why do you want to add that stuff? Power wise will do nothing for you. 100MM TB will not even bolt on to your existing manifold.
Old Dec 18, 2012 | 10:21 AM
I have a 96 mm manifold going on. I got the 100mm TB for that manifold. I am just wonderring if I could use my existing airlid and SLP maf and be good or is it a must to go with the 100 maf and lid?
Old Dec 18, 2012 | 09:57 PM
Blk98Vert's Avatar
You can, but upgrading will net you power
Old Dec 18, 2012 | 10:59 PM
I found some billet 100mm maf ends. I did a search but only found ported maf ends. they are 75.00 shipped. Are they worth the price? Isnt a 100mm maf just a stock maf with ported ends anyway?
Old Dec 18, 2012 | 11:19 PM
Blk98Vert's Avatar
A 100 mm MAF is an LS7 sensor in a 100mm tube
