Throttle body sizing???
Old Jan 23, 2013 | 09:20 AM
EricYJ-TA's Avatar
Default Throttle body sizing???
I recently acquired a FAST 102 mm intake. My question is what size throttle body and maf combo are you guys running. And how do the effect the tune and driveability?
Old Jan 23, 2013 | 10:19 AM
LS-ONE_DAY's Avatar
At least a 90mm. If you don't want to worry about possibly having to grind/shim to get the 102mm tb to fit get a fast or nick williams 92mm
Old Jan 23, 2013 | 10:45 AM
mikh338's Avatar
i have read quite a but that guys with the 102mm manifolds really like the 92mm tb. when i finally get to do this, thats the combo i will run
Old Jan 24, 2013 | 02:17 AM
bww3588's Avatar
Power wise, there will be no difference. Theoretically, you could put a stock tb on it or a 200mm tb. The engine will only take as much air as it wants.
If the engine doesn't want more than the 90mm tb can flow, going larger will not help any.
Idealy, you want to run the smallest tb you can without choking the engine to keep throttle response and low speed driveability good.
Old Jan 24, 2013 | 02:37 AM
lemons12's Avatar
92mm...
