lt headers and intake manifold
Old Jan 23, 2013 | 08:39 AM
2000z28camaro's Avatar
Default lt headers and intake manifold
Looking to do slp lt headers and a fast intake manifold on my 2000 z28, what all do I need other then the gaskets to get the job done?
Old Jan 23, 2013 | 12:18 PM
astro11271984's Avatar
Either corvetter o2s or o2 extentions i would do new header bolts also block of place if you get the ones with egr provisions
Old Jan 23, 2013 | 01:37 PM
99Bluz28's Avatar
Get a set of new intake port seals, and unless this is a FAST 78 intake you'll also need a new throttle body.
Old Jan 23, 2013 | 11:51 PM
dhctss's Avatar
new fuel injectors and fuel rails. It gets very pricy with the fast. i just did ls6 and way better then the ls1. I could only imagine how the fast will perform. It is to bad only one other company makes a oem type intake that is why the price is retarded.
Old Jan 24, 2013 | 12:28 AM
FAD2BLK93's Avatar
Can u run the stock 2000 LS1 TB on a LS6 manifold?
Old Jan 24, 2013 | 01:10 AM
99Bluz28's Avatar
Yes..!
Old Jan 24, 2013 | 01:14 AM
99Bluz28's Avatar
You don't need new fuelrails, unless you're going with a FAST102 intake.
Old Jan 24, 2013 | 08:07 AM
dhctss's Avatar
Fad2blk. If you cant decide look at this way. I was able to clean debris behind old intake,cleans heads,and get rid if olily ls1 intake from oil consumption. You will gain nice throttle response,better gas mileage, and youcould resell for at least 300 down road.make sure you have new pcv valve the updated truck one. Im getting 3mpg more with new intake and with mymods i gained a good 15 hp im sure. Car rips bro
Old Jan 24, 2013 | 08:18 AM
FAD2BLK93's Avatar
Here comes tax time, i will be getting one soon, thanks!
