Best tool to shave bottom of LS6 intake?
Old Jan 31, 2013 | 08:16 PM
94Z28-MSTGKLR's Avatar
Default Best tool to shave bottom of LS6 intake?
I don't plan to use a coolant line relocation kit to install my LS6 intake. I was just going to shave off the fins on the bottom. I've seen a few write-ups on how to but unless I overlooked it, no one mentions what the best tool to do it is. I would rather it be a hand tool and nothing powered. Thanks guy.
Old Jan 31, 2013 | 08:21 PM
Zmg00camaross's Avatar
Hammer and chisel, lay chisel pretty flat and tap with the hammer the ribs will fly off with ease, took me all of five minutes.
Old Jan 31, 2013 | 08:54 PM
10droped's Avatar
Yup I used a wood chisel worked good just make sure to blow it out good when your done those little pcs go every where
Old Jan 31, 2013 | 08:57 PM
obie86's Avatar
x3 for chisel and hammer
Old Jan 31, 2013 | 09:32 PM
VandykeT/A's Avatar
Flat blade screw driver as a chisel works to.
Old Jan 31, 2013 | 10:27 PM
Sounds like a plan. Thanks for the information. Now to start working on it tomorrow.
Old Jan 31, 2013 | 10:36 PM
stealth355tpi's Avatar
air grinder here, no problems
Old Jan 31, 2013 | 11:39 PM
DropTopBird's Avatar
Definitely a grinder. Tried it with a dremel and it was taking forever to do one row of fins. Switched to an angle grinder and zipped all of them off in under 10 min
Old Feb 1, 2013 | 05:48 AM
dhctss's Avatar
X4 nice sharp wood chisel. Better off doing hole thing i only did part and wasnt enough
Old Feb 1, 2013 | 06:36 AM
ramairetransam's Avatar
chisel here too , grinding takes forever and the chisel does a better job , i think i did the whole thing in like 10-15 min , just take your time.
Old Feb 1, 2013 | 09:17 AM
1981TA's Avatar
Chisel is the way to go, and if you want it to look pretty afterward, clean it up with a file or dremel tool
Old Feb 1, 2013 | 09:43 AM
mike171562's Avatar
i used a flat head screwdriver, make sure you flatten it out so you dont punch through the intake.
Old Feb 1, 2013 | 05:10 PM
GarrettM's Avatar
I used a dremel with the little cut off wheels. It was a pain in the ***. The plastic kept melting and smoothing over the wheel. Chisel all the way.
Old Feb 1, 2013 | 06:22 PM
s346k's Avatar
as mentioned above, i used the chisel method, as well. worked great. i then hit it with some sandpaper. smooth as a baby's ***.
then i broke my oil pres sending unit. that's what sucked. i guess 1 out of 6 installs isn't bad
Old Feb 1, 2013 | 07:19 PM
Seems like majority rules. I'll grab the screw driver and light hammer to handle this. Haven't gotten to it yet. Thanks again for all the replies.
Old Feb 1, 2013 | 07:38 PM
Mean87SS's Avatar
Old Feb 2, 2013 | 09:50 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Hmmm..... seven for the chisel, two for a screwdriver. And the screwdriver is the majority??
Use a fresh sharp wood chisel. You'll only need to lightly tap on it to shave the ribs.
Old Feb 2, 2013 | 01:14 PM
mjs1012's Avatar
Hammer and chisel took me 10 min and it was fun to see how far I could get the ribs to fly off lol.
Old Feb 2, 2013 | 01:16 PM
SMOKNSS's Avatar
I dont think I have ever used anything but a flathead screw driver and a hammer. Atleast 10 installs and troblem free.
Old Feb 2, 2013 | 01:32 PM
omarrakeen's Avatar
hammer and chisel, beat the crap out of that thing! worked amazing and felt like it was polished..
