Dies unless giving gas
Old Feb 17, 2013 | 12:18 AM
bradw18's Avatar
Default Dies unless giving gas
I'm stumpped. Runs good once warm but dies after a good rev 4k or above it'll die when coming back down or sputter real bad V2 cam ported heads 36 lb injectors th350 4500 stall very strong just don't want to run after I hit the key with out a little gas I have a mail order tune. Any sujections? I'd love to hit this thing lined out... One warm it'll it'll but surge some times no egr 85mm intake to vacuum leaks i can find.
Old Feb 17, 2013 | 06:21 AM
Old Geezer's Avatar
The tune needs some "TLC".........
Old Feb 17, 2013 | 11:34 AM
bradw18's Avatar
Talking to a running company said since I'm running a 601 601 lift cam I might have to drill the hole in the throttle body
Old Feb 18, 2013 | 08:57 AM
VandykeT/A's Avatar
Check your battery connections but if it has never idled since the tune that would be my guess.
Old Feb 19, 2013 | 08:46 PM
bradw18's Avatar
once warm it idles. just dies if i hit the key with out giving it gas like a old school sbc. and once warm i can rev it pretty high 5k or above and wants to die
Old Feb 20, 2013 | 04:36 AM
therabidweasel's Avatar
Do not drill your tb.
My bet is your tune is not using the iac correctly. I had this problem from a crappy dyno tune I paid big money for. Took it to a different tuner and he said my iac tables had been zeroed out or in some cases the iac was not following the rpm or tps (not sure which) which meant that the iac could not jump quickly enough to provide a soft landing for the transition back to idle.
Iac is meant to handle idle and smooth out when the throttle is abruptly chopped. Sounds like your mail order tune is closer than my first dyno tune...which was also my experience as I had a frost tune first.
Old Feb 20, 2013 | 07:36 AM
VandykeT/A's Avatar
I had a Torquer 2 on a mail order. It acted exactly like a small block with no choke. If I kept it running for 20 or so seconds it would take off and run fine. If you can't find any vacumm leaks and you've got no codes I'm betting tune. Call whoever done the mail order and talk to them about it. See what they say.
Old Feb 23, 2013 | 09:19 AM
bradw18's Avatar
Thanks guys need to break down and buy tunins software so I can tell tuners what the hell is going on. But just bough a ws6
 Michael S. Palmer
