Can i do this?
Old Feb 21, 2013 | 10:36 AM
CamaroFreakls1's Avatar
Default Can i do this?
Mods in sig. I want to spray my car 100 dry shot. Cause it seems simpler and cheaper then wet. The car is my DD i just would like a little more on a button. Would i be safe just doing this kit? Can my stock injectors handle another 100 HP?
This is the dry kit im looking at
http://www.dynotunenitrous.com/store...?idproduct=118
And here is the wet
http://www.dynotunenitrous.com/store...?idproduct=332
I was planning on setting up a Wot switch. But a window switch seemed confusing to set up. This car IS an auto. I know that the window switches are recommended for manuals. What are your guy's thought for i know very little about nitrous except for what i have read on here. What are your guys more experienced thoughts? Thanks Much Appreciated!
Old Feb 22, 2013 | 01:41 PM
Stephen02ws6's Avatar
You would probly get better responses in the nitrous section. But personally i wold go with the wet kit. alot of kits ive seen have a WOT swith so they only spray at WOT, but you can hook up a window switch too. I am puttng a window switch on mine so i can control when it is getting sprayed.
Old Feb 23, 2013 | 09:03 PM
I had it in the nitrous section but didn't get any replys, so I put it here. Lol so run a 150 wet? It's worth the money.? Will I have enough fuel even with my bolt ons? Thanks
Old Feb 24, 2013 | 07:06 AM
I have heard that you can run a 150 shot on the stock motor. make sure you get the right plugs and get a good tune for it. you should change out your fuel pump as well to handle the extra fuel. the wet kit sprays fuel with it so the injectors are ok.
