Would a FAST intake do anything for me??
I had the chance to get one but I drive back and forth from college every couple of months which is 200 miles and the last thing I need is one failing on me. Plus 500 for a used one and 5-7whp is hard to justify.
The I'd like to keep the motor in the car stock internals.I've got friends with cammed cars and while its fun I'd like to keep mine on the low key and see where I can get with a good bolt on LS6 setup.
I know a FAST on a stock ls1 isnt worth much but then again I dont have a stock ls1 long block, people still want stupid amount of money for FAST 90/90 setup but I figure if I wait I can find a good deal and or just get a cheaper 78mm FAST and port it to 85.
Whats everyone's thoughts?
Oh and btw I'm working on a copy of the Chrs1313 ram air so that should also be done this weekend....
I'm curious about your Chris1313 copy. Do you have pics, or can you explain it a little? I'm installing my SSRA today myself
In your shoes I would start piecing together stuff for a cam swap and then toss in a smallish cam.
You can get a decent price for your ls6 stuff to make it even cheaper.
My ls6 put down 370 on a mustang dyno through an Auto. At that time it had BBK 1-3/4 lt's and a mac catback 3". Now its an m6 with bassani td's and ARH 1-7/8" tubes. I'd expect it to put down around 390 on that same dyno now.
So I'm just trying to get all the "free" hp I can out of it without delving into the engine. I think if I find a fast 78 for a deal I'll pick it up port it to 85 and have pretty much a 90 at a much cheaper price, slap an 85mm Prof Product TB on it and let her fly with a new tune of course.
Most all of my mods I have did @ separate times. The intake changes were done on the dyno. The rockers I did at a separate time but I also made a change to a fast 102 then. The fast 102 is not worth the extra cost to you over the 90 or 92. Don't fool with a 78, it's not worth it.
More than one way to skin a cat, but the ls6 cam leaves a lot on the table for a simple swap and a couple hundred bucks with a couple more for springs.
Then a udp and a ewp. With a little more weight reduction I could see a auto full bolt-on ls6 running in the `10's pretty easily since he would holeshot me pretty good.
@ Thunderstruck. I know a cam would put me way up in the hp rankings but as hio said I like having a stock idle and keeping up with a cam only ls1.
Where is anyone finding a fast 90/90 with a tb for 600? Lol i would be all over that. My buddy just got a 92 off craigslist for 500...
but thats a once ina lifetime thing lol. The reason I was thinking about a 78 is its cheaper and it seems once its hogged out to an 85mm snout its very similar to a 90 in power no?I had a chance to get a good deal on an EWP a few weeks back but ultimatley turned it down because as I said I drive to and from college for holidays and its 200 miles and I'm a little afraid of the meziere taking a crap on one of those trips leaving me stranded. Oh and the car already runs an ATI underdrive so I dont think itll get much better than that lol.
Car is 3480 now without me in it so its not too bad but could lose a few lbs I have a small sub in the back so taking that out at the track would take off another 40 or so with the box and amp.
Doug, how was the tuning on yours when you switched to the 90? Did you tune it? I know I'll need a retune but I was wondering if its something I could get nailed down with hp tuners just driving around on my own time or if I'd have to take it back in for a wideband and dyno session?
The car hooks very well suprisingly. Wheels are about as light as you can get for 18's (c5 magnesium) and they're wrapped in 295 bfgs. I can break them loose in 1st anywhere. But theres no wheel hop so I dont see it getting better with a torque arm or anything. Its got lca's and relo brackets now on bilsteins. The DR idea is nice but not so nice for a DD to and from school in all weather.
you forgot to factor in a TB with the Fast unless prices really have come down that much
I was also factoring in the high cost/low hp ratio parts like high lift roller rocker and an EWP he would need to be true full bolt on and come close to the power gain from the cam alone
His signature said M6 and I missed where he said after it was an auto. But I still think bottom 11s or high 10s is optimistic for the setup in most cases. Your car is much more of an exception than a rule.
But if a cam is not what he wants that's perfectly fine too, just putting the information out here
There are fast 90 out there for less than 700 w/tb's. I have bought 2 that way....just keep your eyes open. Yes you should retune with it and it should be ported. I could/would port it for you for a couple hundred. It's amazing how far off they are and still make better power than oe stuff. A good tuner will get you upwards of 15-20 hp and tq threw the middle...maybe more since your ls6 is not ported like mine was. I did not tune mine but I do have the software and have tuned on it a bit. If you have access to efi live I would share it with you. But I also have 42lb injectors.
You should be able to run into the 11's with what you have. I went 11.8 @ 119.8 with very basic bolt-ons after the ls6 on 18's w/o a dr. I never even put a dr on the car to run a 11.5 on the 18's. Car was only about 250lb lighter there, thats pretty to do on these cars.
Thunder my car is no exception to the rule. I could duplicate it easily. The only real crazy thing about my car now is the weight. But I know what it did before and during the weight reduction. It's the little things that add up like getting rid of that neck down after the y to go into the cat back.....or better yet modify the y to make it bigger where the pipes come together. Modifying the airbox and I actually made my own carbon airlid with more volume. Now others are starting to catch up to one of my best mods....the clutch.....I was years ahead of the curve there
And Thanks Doug, If I go that route ill def take it to the dyno and have them retune for the fast. I was gonna ask you about the clutch. Not that it's something is do before the intake but what clutch do you run? I've heard those quarter master clutches are good for maybe 5k at best before the **** the bed?
Also they say they can't be driven on the street? What all did u need for it and what exact clutch is it
Dan-
