Will this oil pan work?
Old Mar 31, 2013 | 09:58 AM
KingPin1094's Avatar
Default Will this oil pan work?
the 6.0L i bought had a broken rod which went through the pan. I just need to know if this oil pan will work: http://www.summitracing.com/parts/na...3/media/images
my only concern is i do not see a place for the sensor, and it just doesnt look the same like the bottom part of the stock oil pan looks longer. Im having trouble uploading a photo so i hope you guys understand what i mean.
Old Apr 4, 2013 | 06:51 PM
WTB: oil pan
Old Apr 4, 2013 | 08:07 PM
64post's Avatar
If it's the GM "hot rod" swap pan for early vehicles with LSX then it does not have a provision for oil level sensor. 5.5qt. capacity? looks like the very same one I am using for LS to Mustang swap. There is a full description of it in the oil pan sticky, take a look.
Old Apr 4, 2013 | 08:09 PM
Decadence75's Avatar
I believe that you should be able to use an LS1 pan with the motor if it is an LQ4/9 6.0
Someone correct me if I am mistaken.
Old Apr 4, 2013 | 08:31 PM
I can but i dont know where to find one. No one seems to be selling one in the classifieds.
Old Apr 4, 2013 | 09:59 PM
Found this in the first few results in a classified search for oil pan
Stock pan with complete with tray and pickup $175
Old Apr 4, 2013 | 11:39 PM
garys 68's Avatar
Any oil pan made for the Gen 3/4 motors will work on any motor, LS1,2,3,6, LQ4,9, etc. But they wont fit every car, ie crossmember, steering clearance. They are also different depths. Check out the oil pan sticky in the conversions forum for dimensions.
Old Apr 5, 2013 | 09:11 PM
Already gone... Will the stock oil pan clear a 4" stroke?
Old Apr 5, 2013 | 09:19 PM
You will probably need to clearance the tray some for the #1 rod as I believe in most cases the bolt head at least will make contact.
