LS1 covers on LS3 heads, Quick question
Old Apr 1, 2013 | 05:55 PM
KingPin1094's Avatar
Default LS1 covers on LS3 heads, Quick question
Okay so i know i need to remove the oil baffle on the passenger side. But do i need to remove the things on the other side? I do not have the harland sharp rockers yet to check the clearances. Im also running an LS6 valley cover. Was going to upload a photo, but im having issues.
Old Apr 2, 2013 | 07:32 PM
anyone?
Old Apr 3, 2013 | 06:59 PM
Ryan@BallisticSpeedParts's Avatar
You will only need to remove the baffles on the passenger side, drivers side will clear the rockers. This is when using GM rockers, you'll want to double check with Harland Sharp rockers
Old Apr 3, 2013 | 07:18 PM
okay thank you very much, most of the covers i have seen dont have those things in there. so i just didnt know. thank you
