harmonic balancer won't come off ???
Old Apr 18, 2013 | 09:10 PM
jaywill's Avatar
Default harmonic balancer won't come off ???
I get it almost to the end and the motor wants to turn over with it when I try to get it off ???
Old Apr 18, 2013 | 09:21 PM
jaywill's Avatar
Old Apr 19, 2013 | 05:16 AM
Slowbird780's Avatar
An impact and a 3 jaw puller
Old Apr 19, 2013 | 08:42 AM
jaywill's Avatar
I'm using a 3 jaw puller... it keeps slipping off ! I'LL WORK ON IT SOME MORE TONITE..
Old Apr 19, 2013 | 08:56 AM
WS.666's Avatar
Use your hands and wiggle it off.
Old Apr 19, 2013 | 10:29 AM
Can u put ur puller on the inside and reverse the jaws? A friend also helps with holding them together if you cant or a ratchet strap
Old Apr 19, 2013 | 11:50 AM
jaywill's Avatar
will try it..
Old Apr 19, 2013 | 01:39 PM
67rally's Avatar
I had the same problem, and had to use a different 3 jaw puller than the first one I tried. I rented it from Pep Boys, and they had 3 sizes. I can't remember now whether it was the mid size or the big one that worked the best, but I'm thinking it was the biggest one.
Old Apr 19, 2013 | 02:50 PM
WSLN 6's Avatar
I had to use a big 3 jaw puller around the outside of the pulley (I know, not the best as it may separate) as a smaller puller would slip off and bend, even secured on every arm.
Old Apr 19, 2013 | 09:12 PM
jaywill's Avatar
Thanks guys i got it off !
