oil pressure
Old Apr 22, 2013 | 07:13 PM
stherngent's Avatar
Default oil pressure
what should oil pressure run around on a new c/h with new oil pump, mine runs cold around 40psi then after warmed up in between 40-20psi?
Old Apr 27, 2013 | 11:44 AM
64post's Avatar
You only need 10 psi per thousand rpm min. but never hurts to a little more. Volume is what you want.
Old Apr 28, 2013 | 03:22 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Is it a ported pump? What kind of pump are you running?
Old Apr 28, 2013 | 03:52 PM
trans_am7935's Avatar
this is important, cause if you just thew a new stock one in, then this sounds about right. with mine i run 70-75psi cold and 45-60psi hot, i have a TSP pump, i also live in WA state.
Old Apr 28, 2013 | 06:25 PM
badazz81z28's Avatar
Do you have the high pressure spring installed (red)? I have an SLP pump with the std pressure spring (Green), I sit about 40psi hot /50psi cold at idle, about 55-60 at speed @ operating temps.
75psi cold is pretty high IMHO.
Old Apr 28, 2013 | 07:14 PM
Firebirdmuscle's Avatar
I'm at about 75 on cold start up once everything gets warmed up after driving its around 65-70
Old Apr 30, 2013 | 08:17 AM
75 psi is quite high. Basically pegging out the gauge...If you guys have 75 PSI at idle with a stock spring pump, you have something going on.
Old Apr 30, 2013 | 08:52 AM
the pump i have is the TSP LS6 ported and shimmed pump, and i am very happy with my psi. yes the pressure is high, but my jeep sits at 70psi cold as well, and as i see it the higher the psi at cold start up the faster the oil will get to all the vital engine parts.
