5.7 to 6.0
Old Apr 29, 2013 | 07:24 AM
blackws620's Avatar
Default 5.7 to 6.0
I searched the forums and havent been able to find the conversion thread that i once found and need to use. It had a detailed description of the hole you have to drill for the alt. bracket and other info i am needing. If someone is able to find it or help me out i would appreciate it.
Old Apr 29, 2013 | 08:55 AM
Rob WS6's Avatar
Its real easy to do, just drill and tap the hole to M10x1.5. Use the alt bracket to mark the center of the hole, hit it with a center punch, drill with the correct drill bit, carefully tap and youre good to go. I did it while it was in the car and it took about 10 minutes.
