Anyone make an adjustable throttle cable bracket?
I have an LS3 with a throttle body bracket from SDParts and a Nick Williams 92mm TB. I regularly have a problem with the cruise control cable retainer not being tight enough on the NW cam arm, so it cracks the plastic and I have to keep replacing the cable and/or also the module maybe 1-2 times each year.
In addition, the bracket is too far forward thus causing too much slack in the cable. But it can't move further backward because it already requires 'customization' of the LS3 noise cover to be installed. I think I've seen some brackets which mount to the valve covers instead and/or are adjustable, but I can't find them now. Not sure if they were home made or if a vendor offers them?
