tsp 1 7/8 vs pacesetter
I dont think whignam and I are saying that the tsp's you have dont measure that on the inside were merely saying that headers are measured to the O.D which could mean you have the wrong set of tsp's.
I had a set of aluminum Hookers on there and finally replaced them once they started to rust and look crappy. I'm sure there was some nominal performance benefit to stepping up to 1-7/8", however it didn't feel like enough to make it worthwhile if that was my only motivation for doing it.
I linked you To anther thread in the dyno section where the tsp rep even quoted they measure to the od I suppose it is possible pacesetter uses cheaper thinner tubing which would skew measurements but idk
Here's another explaining everything http://www.camaro5.com/forums/showthread.php?t=285935
