Fast 301311 Ignition what are the cons?
Old May 21, 2013 | 11:58 PM
Kam48j's Avatar
Default Fast 301311 Ignition what are the cons?
Hello everyone So I just got a 1972 chevelle roller and picked up a 98ls1 with t56 don't have harness or the computer so I was thinking about get the fast controller for it my buddy have harness from 2000 z28 but I can take heads off and put cam and timing chain etc but wiring makes me go crazy so the fast have simple hook and everything is in the one pack. So what should i do buy fast or get stock harness reworked and buy stock computer and get the codes worked ? Any disadvantage or advantage to going with fast or stock. Here is the one on eBay http://www.ebay.com/itm/FAST-Ignition-Controller-Kit-with-Plug-N-Play-Harness-for-GM-LS1-LS6-301311-/190833418358?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6e8ee076&vxp=mtrPlease help....
Old May 22, 2013 | 12:26 AM
Kam48j's Avatar
Unhappy
Wow 40+ view no reply
Old May 22, 2013 | 08:26 AM
2000PewterT/A's Avatar
I don't see anything wrong with them, but this is coming from someone who has never worked with that system so I couldn't give a true answer. Hopefully someone who has worked with it will chime in.
Old May 22, 2013 | 08:29 AM
ls6jay's Avatar
Wiring not hard. Basics just need two batt. Hot . Two ignition hot and two grounds and it will run. ( with all sensors and pump hooked up).
Old May 22, 2013 | 10:35 AM
Kam48j's Avatar
But that's after the factory harness is modified which I won't be able so that's why I was looking at fast everything is already done yes four wire hook up will be a breeze
Old May 22, 2013 | 07:33 PM
Kam48j's Avatar
Any tuner here would know?
Old May 23, 2013 | 01:26 AM
Kam48j's Avatar
to the top
Old May 23, 2013 | 01:02 PM
Kam48j's Avatar
Never mind i ended up calling fast that part only controls ignition no fuel so to get the whole setup its fast part #302002 which is $1400 so its safe to say go with factory harness and computer.
