sputtering while driving after heads and ca?
Old May 30, 2013 | 11:46 AM
blackfbird98's Avatar
Default sputtering while driving after heads and ca?
just did a tsp v3 cam and prc 2.5 heads, car has been running great the past couple days but lately when im cruising the car will start to hesitate and sputter and the check engine will flash? i checked my plugs and wires and they seem ok, im also running the stock injectors for now untili have my tuner swap to my 42# injectors but im not sure if the stock injectors may not be supplying enough gas and that might be causing it to sputter?
Old May 30, 2013 | 11:49 AM
HCI2000SS's Avatar
Is the car tuned for the heads and cam? Is it hesitating and sputtering under hard load or light driving or what?
Old May 30, 2013 | 11:52 AM
car is not tuned yet, it is sputtering randomly regardless of weather or not im going hard or light driving, for example i just drove it for about 30 miles and had no issues but earlier in the day it did it twice when i was cruising.
Old May 30, 2013 | 11:56 AM
HCI2000SS's Avatar
Well not being tuned with something as major as new heads and a cam could very well be the issue. You are changing the whole dynamics and compression of the engine at that point
Old May 30, 2013 | 12:02 PM
i agree with you, i just wasnt sure if the problem was because of that stuff or if it was a separate problem like i said it drives just fine 1 min then it will randomly sputter.
Old May 30, 2013 | 12:07 PM
KevinR's Avatar
Yeah, you have to get it tuned. A flashing SES light normally indicates a misfire which is common when you upgrade the cam and will occur until you get it tuned. Whatever you do, do not go WOT until the car is tuned.
Old May 30, 2013 | 01:20 PM
HCI2000SS's Avatar
Well it could also be something else (who knows) but you definitely should start with a good tune since that's like it
Old Jun 1, 2013 | 12:50 PM
Here's and update, I hooked a scanner up and am getting p0300 obviously because of the cam but I'm also getting p0131 for bank 1 sensor 2 low voltage. Should I just replace the sensor or where else should I start? The car does misfire so that's why I'm leaning towards just replacing the sensor
Old Jun 1, 2013 | 01:10 PM
camarochvy21's Avatar
Just get the car tuned man, it will solve all your problems
Old Jun 1, 2013 | 01:28 PM
I don't wanna end up going to the dyno and find out I can't have it tuned cause something else is wrong. This car should not be physically misfiring something is up
Old Jun 1, 2013 | 06:02 PM
my question is at this point is if that p0131 code can cause a misfiring?
Old Jun 1, 2013 | 07:52 PM
Old Geezer's Avatar
Question How about...
Symptoms
Check Engine Light will illuminate
Vehicle may idle or run rough
Decrease in fuel Eeconomy because PCM is in a "limp home" mode
Engine dies
In some unusual cases, there are no adverse conditions noticed by the driver
Old Jun 2, 2013 | 03:17 AM
ls1 1990 VN's Avatar
You have just changed heads & cam.....GET the damn thing tuned! you shouldn't even be driving it around like you are.
Old Jun 2, 2013 | 10:14 AM
flattusmaximus78's Avatar
My car threw the same codes. Cam is making the car think it is misfiring. Get it tuned. Bring a extra set of plugs and 02s if you want to feel better at the dyno.
Old Jun 2, 2013 | 11:58 AM
i had a stall put in hence why im driving it, i needed to break it in for a bit before having the **** beat out of it on the dyno
Old Jun 2, 2013 | 12:13 PM
alexus6798's Avatar
You really need to listen to everyone's advice and get the car tuned. You have heads, cam and a stall/without a tune and still riding around. Your pcm is having a fit trying to figure out what to do.
Old Jun 2, 2013 | 12:28 PM
i am having it tuned on tuesday, thats the soonest i could have gotten in ive had the appointment for a week now i just wanted to make sure that when i go to get it tuned that im not gonna be shunned away because i have something else going on with the car.
Old Jun 2, 2013 | 04:48 PM
You sure will have if you keep driving it like that!
Are trying to 'bed in' 'break in' 'run in' your stall? What for!! like diff gears, once installed correctly, drive it like you stole it.
Old Jun 3, 2013 | 03:47 PM
I broke in my stall with wot pulls!
Old Jun 4, 2013 | 12:39 AM
Why were you doing wot pulls on an untuned H/C install anyway.
You don't have enough power going on to damage a stall, obviously it was faulty in the first place.
