Belt part numbers for ATI 10% underdrive pulley
Just picked this damper up:
http://texas-speed.com/p-2440-ati-se...ac-pulley.aspx
What part numbers would I need for the serpentine and a/c belt? Sizes?
Gatorback part numbers would be nice
4040400
http://www.goodyearep.com/bulandingpage.aspx?id=52
http://partfinder.veyance.com/
See if these P/N's work. I went to the Goodyear site for belts and found this info. You can navigate your way around and see if you concur with my findings.
if you want me to install the belts just call my secretary and set up an apointment!!
HA!!
Just kidding, hope this is what your lookng for. Help out a fellow Hot Rodder some day if possible. Give thanks to God for making Chevrolet!
Chad
4040400
HA!!
Chad
4060360? The original Gatorback I had on was 4060790 which equates to a 79 in. belt, with that other part number that means it's a 36 in. belt. Is that right? Seems kinda short, if I'm reading ATI's brochure correctly they give part numbers:
4060775 and A/C 4040390 which would equate to a 77.5 in. belt and 39 in. belt respectively. I'll try to call them today to verify that those numbers are correct.
