E85 Plugs
Old Jun 12, 2013 | 10:24 PM
ss4chad's Avatar
Default E85 Plugs
I am doing a speed density tune and running E85. I have bigger injectors now (was 42lb, now 60lb) that will be 72lb with my bigger fuel pump.
Should I run a hotter plug than my previous plug, NGK TR55?
I have a bigger motor, crank, heads, intake, TB, etc..... than my previous stock bottom end with heads & cam.
Chad
Old Jun 12, 2013 | 10:36 PM
Atomic's Avatar
I need a gauge for that
Any boost or nitrous?
Old Jun 13, 2013 | 05:37 AM
ss4chad's Avatar
No, all N/A. I may spray a 150 or 200 latyer down the road but for the next year or so it will be all throttle.
I thought a hotter plug might be warranted since I am pumping much more fuel from the stock set up or the H/C that was in it, not to mention more fuel consumption due to the E85.
Chad
