Intake swap plus injectors??
Old Jun 19, 2013 | 08:34 AM
keith67chevelle58's Avatar
Default Intake swap plus injectors??
I recently finished doing an LQ4 conversion in to my 67 Chevelle, I would like to swap the truck intake for an LS6, will I need to replace the injectors and connectors for it to work? I am not building a racecar or a high HP motor, just a dependable cruiser. Thanks
Old Jun 19, 2013 | 08:44 AM
LS1-450's Avatar
Different "O"-rings on LS6 intake injectors. The "O"-rings are slightly smaller. However, if you lube the LQ4 injectors & are careful, you can push the LQ4 injectors (w/larger "O"-rings) into the LS6 injector bore. Connectors will work.
