How much oil in intake is normal?
Old Jun 23, 2013 | 10:30 PM
VandykeT/A's Avatar
Default How much oil in intake is normal?
I just got done pulling my 102 intake from my car (still hot) with the intentions of painting it. When I got it apart I noticed the intake ports were a light brown color (on the heads) and feeling of the inside of the intake it feels pretty slick almost like a very very very light oil film is there. Is that normal? Its not like its all coated in oil it just has a light greasy film. I took degreaser to the inside of the intake but if any oil texture isn't normal I don't want this to happen again. I also have a Norris catch on the car.
Old Jun 24, 2013 | 12:01 PM
98Zheadsncam's Avatar
Wow, I just made a similar post and didn't see yours. Yea, my intake was the same way. And, I'm also running a Norris catch can. I think the only way to truly get rid of that oil is to delete the pcv and run breathers, or run a vacuum pump.
Old Jun 25, 2013 | 04:10 AM
dhctss's Avatar
When I put the ls6 intake on 3 months ago my ls1 intake was filled with oil. I then added a norris catch can myself and hopefully it has cut down a little but like stated above to remove valve would be best bet. Thats the problem with the faulty system these engines have.
Old Jul 1, 2013 | 12:18 AM
99Bluz28's Avatar
Try either shielding the CC from the exhaust/engine bay heat, or move it to a cooler location. That will help trap more oil and water in the CC.
Old Jul 2, 2013 | 12:27 AM
01ssreda4's Avatar
Completely normal, even after low mileage.
Old Jul 2, 2013 | 08:31 PM
garygnu's Avatar
I like the idea of moving the catch can to a cooler location,consider insulating it also.
