About to install the long tubes.
I ran into an issue with the wiring going to the starter. The wiring loom is approx 1/2" from the header. Is this going to burn the wiring? Is there a way to shield it from the heat?
Tomorrow I hope to finish the install up and drive the car. Just have to put the alternator back in, swap the pins in the PCM plug for the o2 sensors, fire it up open headers, and last but not least install the y pipe.
BTW... I did fire it up open headers to uhh.. uh... make sure everything was hooked up. The neighbors loved it.
I noticed additional vibrations from the poly motor and trans mounts. I think it will be easy to get use to.
My plan before even starting was possibly running the rear up on ramps then jacking the front up to match...idk yet.
All said and done we had about 8-9 hrs into it, and we definitely weren't working at break neck speed. One thing that really helped was the undercarriage of my car is almost spotless and everything came apart like butter.
