Can I run no MAF??
I am wondering if it is possible to run no MAF??
The set up that I am going to be running is a FTP 98mm Lid and a FAST 102mm. If I have to run a MAF I would get the SLP 85mm.
Please give me your feed back. I am tunning this with a HP Tuner Pro.
With speed density, you need to keep changing the tune with the different air conditions when it changes from the day you tuned it. However, if you own the tuning program and know how to, it's not a problem. Speed density is way better than reading off the MAF though.
I drive it only during the summer due to me living in Montana and the temp changes here a lot... So it looks like I will be running a MAF then.
So next question is what MAF should I use???
