Installing Asp crank Pulley! Need Advice!!!
I can't believe it is that hard of a install.
Thank's
jdog36(02 T/A Vert)
P.S. will I notice any Gains???
Also, lubricate the old bolt threads when you are seating the pulley. I found a large washer to place between the Al pully and the bolt because I was not liking the galling the head of the bolt was causing on the Al of the ASP pulley. If you decide to use a washer use it for the last half or third of the install.
Good luck and the above writeup is good.
Thank's
jdog36(02 T/A Vert)
Yeah, I did mean a 1/2" drive. Imagine trying to take off the crank bolt with a 1/4" drive ratchet!
