what is this port on the TB for?
Old Jul 13, 2013 | 07:35 AM
awd-rwd racer's Avatar
Default what is this port on the TB for?
just wondering if this was a coolant tube that was capped off or is it a vacuum port. thanks!!
Old Jul 13, 2013 | 07:51 AM
Decadence75's Avatar
That hose connects back to a vent port on the valve cover.
Old Jul 13, 2013 | 09:49 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Yep. Should connect to the front nipple on the passenger side valve cover.
Old Jul 14, 2013 | 07:42 PM
libertyforall1776's Avatar
I don't know that I would trust your zip ties to hold up to under hood temperatures, better to use the right tool for the job with some metal hose clamps...
Old Jul 15, 2013 | 03:29 PM
joecar's Avatar
That port is the fresh air supply from upstream of the throttle blade.
Old Jul 15, 2013 | 03:32 PM
joecar's Avatar
[ if that nylon ziptie ever did melt, then there would be other more serious problems (all the other plastic components you see in the engine bay) ]
Old Jul 15, 2013 | 03:59 PM
white2001formula's Avatar
Not to sidetrack, but what method are you using for the accelerator cable? Mine is busted up, and I was considering doing something like this...
