header rubbing k-member how much can i remove?
Old Jul 19, 2013 | 10:23 PM
REDLSX's Avatar
Default header rubbing k-member how much can i remove?
Just installed tsp 1 7/8 headers and duals and was getting a bad vibration at 2k rpm and sure enuff the header is laying right on the k-member.. how much can i safely grind off the K? Looks like i need to remove at least a 1/4 inch..
Old Jul 19, 2013 | 10:59 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The factory k-member is a very beefy piece...I don't think you'd have a problem grinding off that much. My Kooks 1-7/8 headers were very close on the passenger side, but my poly motor mounts kept it from hitting.
Old Jul 20, 2013 | 06:00 AM
01ssreda4's Avatar
I removed 1/4 inch or more on mine to clear LPP stainless headers back in the day. No big deal that thing is stout.
Old Jul 20, 2013 | 08:20 AM
REDLSX's Avatar
Thanks guys. Yeah its not a matter of hitting under throttle, the collector tube is accually smashed up against it just sitting there..its crazy how much these cars vary in their build..
Old Jul 20, 2013 | 10:28 PM
AmarilloWS6's Avatar
Mine was doing the same thing. The header was just smashed up against it, I had poly motor mounts, and my car used to buzz, rattle, and vibrate really bad at red lights and idling but I just thought it was the extra vibration that everyone talked about the poly motor mounts adding. I ignored it for about a year until my car was on a lift and realized what was causing all the really bad vibration and buzzing. I pry'ed back on the header a little bit and had a buddy whack a good portion off with a cutting torch. The car felt brand new afterwards, absolutely no vibration or buzzing was present. You'll be safe to take off that much, those k-members are freaking huge and beefy.
