tips on getting my duals back off the car..
Old Jul 20, 2013 | 11:20 AM
REDLSX's Avatar
Default tips on getting my duals back off the car..
Im rubbing the k-member with the header so i need to notch it out but i cant get the duals to break free at any part.. only been on the car 3 days but its like they are welded on.. i just used the supplied tsp band clamps..
Old Jul 20, 2013 | 11:37 AM
GoodSpeed150's Avatar
Can you just cut the notch in the k member without pulling the header/true duals?
Old Jul 20, 2013 | 04:21 PM
reinhardt02's Avatar
I am thinking take the motor mounts loose and jack the motor up and over to make room to grind on the frame. Has got to be easier than taking the exhaust out.
Old Jul 20, 2013 | 07:25 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
2x4 in front of the X and smack it with a hammer. I speak from experience
Old Jul 20, 2013 | 08:01 PM
AmarilloWS6's Avatar
Whenever my header was up against my k-member I got a pry bar and lightly pry'ed the header away from the k-member while a buddy got his cutting torch and cut the k-member, no disassembling anything. Might give that a go first before doing the extra work
Old Jul 21, 2013 | 08:19 AM
A cutting torch is a wonderful thing. Saves so much work. Where are you located? Maybe a member could help you out.
