Think I wiped out my front crank seal?
What, that washer deal the guy has been advertising for aligning the front cover? No, because your oil pan hasn't been taken down. Just some RTV for the corners at the bottom and some red loctite for the cam bolts (if you didn't already have it on there.)
It really isn't necessary to check out the timing set as most people have pointed out. But after seeing the damage from a cam gear bolt walking out, I'd check it out.
