ls6 intake question
Old Aug 12, 2013 | 08:26 PM
EdgarB's Avatar
Question ls6 intake question
Hello to all, In a couple weeks I intend to swap to an ls6 intake for my camaro, I currently have the intake, (2) air and (1) egr block off plates for my headers along with gaskets. I have read that you can use the stock coolant lines as long as you dremmel or remove the fins under the intake, Is that true? If I do reuse the lines will I still need the rear coolant plugs? If anyone could point me to a good write up on someone who reused the lines it would be great.
Thanks
Old Aug 12, 2013 | 08:40 PM
blown97ss's Avatar
I just did mine and used the stock ls1 lines no problems just knock the fins under the intake off.
Old Aug 12, 2013 | 08:48 PM
EdgarB's Avatar
did you need the 2 plugs in the back?
Old Aug 12, 2013 | 09:11 PM
2000PewterT/A's Avatar
Don't plug any of the steam ports, it can cause problems and some cylinders may run hotter than others. You basically have 2 options, either run the ls6 coolant crossovers or knock/grind off the fins on the bottom of the ls6 intake. I used the ls6 lines and brazed them shut at the open end, I prefer this over modifying the intake.
Old Aug 12, 2013 | 09:30 PM
EdgarB's Avatar
alright so dont follow the ls1howto write up on the plugging part correct?
Old Aug 13, 2013 | 07:27 AM
EdgarB's Avatar
Bump. Still looking for a good write up using stock lines
Old Aug 13, 2013 | 09:25 AM
thunderstruck507's Avatar
no write up needed...either hold up the ls1 lines to the intake and chip away the fins until it will sit flush on the bottom of the intake or order the ls6 coolant cross over and 2 block off plugs
or do like me and the poster 2000pewterT/A did and cut out the section of pipe that runs under the intake and braze the tubes closed, but this method is more involved and risks coolant leaks if you do it wrong
you're over complicating it
Old Aug 13, 2013 | 09:27 AM
or google "ls1 coolant line ls6 intake" and click images...this is one of the first ones
Old Aug 13, 2013 | 04:40 PM
EdgarB's Avatar
Thats exactly what I needed. Just to double check, No plugs if I use the stock lines correct?
