What spark plug wires work with 1 inch valve cover spacer
Old 08-15-2013 | 11:11 AM
schnellttz06's Avatar
Default What spark plug wires work with 1 inch valve cover spacer
I had to get a one inch spacer to fit my valver covers over the poly locks for my roller rockers, now Im pretty sure my spark plug wires aren t long enough. Anybody know of some wires that are about an inch or so longer than stock, I dont really want to make custom wires if there is a set ready to go.
Thanks
Old 08-18-2013 | 11:07 PM
Hamrdown's Avatar
MSD cut to length wires. Just make sure the boots are correct for an LS1.
Old 08-19-2013 | 08:10 AM
Streetlegal?'s Avatar
I have the rest of this kit I used from my coil relocation if you would like it. There is a ton of wire left and the spark plug connection ends. You have to buy the LS1 coil boots though because they don't come in the kit. IIRC it was $25 for all 8. Pm me if you want it. Here's what I have left. The long ones are the longest in the kit and I think are almost 4ft long.
Old 08-19-2013 | 09:43 PM
Ok,Thanks. I got my spacers and did a little mock up and I think stock size wires might actually work. But Im starting to think I should have gotten the 3/4" spacers. Still not sure if its gonna fit under the alternator.
Old 08-24-2013 | 07:02 AM
LS1MCSS's Avatar
Truck wires are 1 1/2" longer than car(f-body) wires, if that helps.
Old 08-24-2013 | 07:33 AM
MikeFSKSpeed's Avatar
MSD Car Wires P/N 32819 are 9" Long, Truck Wires P/N 32829 are 12" Long
Then the Cut To Fit LS wires are P/N 32079 and are about 4 ft long
Old 08-24-2013 | 10:03 AM
Thanks, that does help. But now I think Im going to try to run 1/2 or 3/4 inch spacers since the coils wont clear the rear of the alternator. Always something.....
