Lsx alternator wiring help please
Old Sep 24, 2013 | 01:43 PM
huggerorange69's Avatar
Default Lsx alternator wiring help please
Ok I've got a 4.8 with a carb, I've been trying to get the alternator to charge but I'm having now luck. It's a truck alternator, the pigtail came off a 2003 Chevy 1500 4.8. I've tried booking up the brown wire, and nothing. I have a 12 volt source. The stud is hooked to the battery. What do I need to do??
Old Sep 24, 2013 | 03:33 PM
Summitracing's Avatar
LS1Tech Sponsor
This may help, Painless Performance makes an CS130D alternator pigtail for this type of issue when going to a carbureted application on the LS engines. This should make the wiring process straight forward.
__________________
800-230-3030
www.SummitRacing.com
Old Sep 24, 2013 | 07:04 PM
Gray86hatch's Avatar
The easiest way is to install a self exciting regulator. Then just hook up the lead to the battery.
Tim
Old Sep 25, 2013 | 08:22 AM
Is there no way to just use what I have?
Old Sep 25, 2013 | 09:00 AM
Yes you can install a resistor. Google there is plenty of info. I had mine that way at first and it didn't charge as consistent as the new regulator.
Tim
