will i get gains from a FAST 78mm intake?
my car is a stock long block for now (cam later on)
i have the weiand air gap aluminum intake on there now. ported/polished throttle body. i can get a fast 78mm from a friend, would that help me much being the same size intake or should i just save up for the bigger?
also my Nitrous plate kit is 78mm
I would not expect you to gain much if anything, but I definitely prefer the composite intake manifold setups over the aluminum in most cases. I would recommend saving up and when you are ready to upgrade go with the Fast 102 setup. Keep in mind you will need to upgrade to a 102 nitrous plate as well.
Ive engine dyno tested the FAST 78mm on a stock LS1 engine, with an LS6 manifold.
The FAST 78mm made definite power gains through the entire RPM range. Although not a direct comparision, most non fast LS manifolds basically are equivalent to the LS6 from my research. So tha FAST still should easily make more pwoer than your wieand
But don't forget the primary gains from a Fast intake are in the design of the manifold and it's runner sizes which are behind the TB and are the same for the 78/90 and I believe the 92 had slight revisions.
the 102 is a whole new design
I think the price will be the factor here. I would stick with the LS6 intake, if the seller is out of his mind. I have seen old 78s for as much as $650! I would pass, wait, and save for at least a FAST 92. I don't think the FAST 78 is the same as the 90/92....I'm sure I have read that somewhere.
The only difference was the top shell which is what the snout is built onto.
IMO a 78mm is a good option especially for a bolt on or cam only car that will be limited by head flow before it is limited by TB size. You can use the stock TB if I recall so you cut down $200+ from the price of the swap and don't have the tuning headaches of the bigger TB. Then later it can be either ported to 85mm or you might find a 90mm upper shell from a broken intake to swap on.
I generally see them sell for $400-450 but it's rare they turn up at all. So it's up to the buyer if it is worth the extra price over a ls6. I would expect one to gain ~10rwhp over the ls6 intake.
