milled 243s to 53cc
Old Sep 25, 2013 | 04:48 PM
tony1784's Avatar
Default milled 243s to 53cc
i have a set of 243s milled to a 53cc chamber, how much were they milled?
will i have sealing issues with a LS6 intake?
Old Sep 25, 2013 | 07:20 PM
1BAD98LS1's Avatar
They were milled quite a bit, sealing will be an issue with the composite intake
Old Sep 25, 2013 | 09:37 PM
tony1784's Avatar
well ****! lol.
what other intakes are better for this situation?
Old Sep 25, 2013 | 09:57 PM
1BAD98LS1's Avatar
Edelbrock Vic Jr / Supervic Alum intakes. I personally would go supervictor...
Old Sep 25, 2013 | 10:03 PM
rawlsfwqq's Avatar
I have no idea what to make of this.
Old Sep 25, 2013 | 11:28 PM
RobsZ28's Avatar
I had my 243's milled to 60cc and the machine shop said they milled them .020. So that would be .005 milled for 1cc I would say a rough guess is that your heads were milled approximately .045.
Old Sep 26, 2013 | 09:47 AM
tony1784's Avatar
how do i keep that under the cowl?
Old Sep 26, 2013 | 09:56 AM
Rise of the Phoenix's Avatar
You'll have to do some cutting. If you get the Scorpion 4150 TB, it will fit, or so I've been told by people who run that setup.
Old Sep 26, 2013 | 11:08 AM
tony1784's Avatar
****, really didnt want to cut up the cowl
what about one of these?
Old Sep 26, 2013 | 11:24 AM
You'll lose a lot of power with the elbow. Some have lost as much as 50 HP.
Old Sep 26, 2013 | 03:36 PM
tony1784's Avatar
holy ****. yeah dont want that to happen..
what do you run as a air filter if i use a 4150 style throttle body?
Old Sep 26, 2013 | 03:40 PM
Check out the thread in the internal engine section on here. There is a guy running a super Vic with a 4150 TB and he has a very small filter he runs on the street. No idea what brand it is or where he got it at.
Old Sep 26, 2013 | 06:59 PM
tony1784's Avatar
after thinking about it, and seeing those pictures of what people cut to make a 4150 work on their f-body, i really dont want to do that, is there any other options as far as a long runner style intake that will still fit under a stock cowl and hood?
Old Sep 27, 2013 | 04:50 AM
LS1MCSS's Avatar
It doesn't matter what kind of intake you run, you're still going to have sealing problems. Those heads have had a lot milled off of them.
Old Sep 27, 2013 | 08:16 AM
That is true, but an aluminum intake can be milled to fit the heads. Can you mill a plastic intake; I guess you can, but I sure wouldn't take that risk.
Old Sep 27, 2013 | 09:40 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
ProFlow XT?
Also, you CAN mill the face of the intake to get it to line up better. Another thought...
Old Sep 27, 2013 | 09:58 AM
AGearHead4Life's Avatar
I've milled my heads .045" with a LS6 intake and no noticalbe sealing problems yet.
Old Sep 27, 2013 | 10:03 AM
I would have guessed that's a .060" mill.
Old Sep 27, 2013 | 10:14 AM
usually around .007" per CC. Your stock heads are about 64cc. Subtract 53cc leaves 64-53=11. So the missing 11cc mulitplied by .007 = .077.
But that just doesnt sound right. Sounds like too much. So I adjusted my guess to .060. That'd be .0055 per CC. .0055 x 11 = 0.0605"mill or "60 thousandths".
I also adjusted the guess down because Robsz28 got .005" per cc. But If Rob is right and its only a .045" mill, you should have no problem running your LS6 intake on them. I'm doing it right now.
Old Sep 28, 2013 | 07:52 PM
IllusionalTA's Avatar
You you can use a rough .006 per cc but as the chamber goes horizontal you'll begin to suck up more cc per thou in the mill.. give it a shot as far as plastic goes you'll probably have issues with the locators on the intake, mill the intake face on heads and you can get it done if you dobt wanna chop the cowl
