HELP! Car running terribly after header install
Fast forward to today, car is at the shop getting pinion seal in rear end done. In addition the missing O2 extension was installed. After work is completed my mechanic calls saying the car is driving like total **** and misfiring? So yeah...
I don't understand how it ran better with a missing O2 than with both?
Edit: I'm reading a lot of threads with people with the same issue but all of them die out without the OP ever solving his problem (or he just never updated the thread saying he fixed it and what the issue was). However the most common problems seems to be a cracked spark plug or burnt wire. Is this likely my issue or would the car have ran like crap from the beginning if that was the case? Whats weird is that it just started running bad today. Another possibility is a stripped O2? Also maybe a bad IAT sensor which is not header related but maybe coincidence? Is there any way to tell what exactly the problem is before I start randomly replacing parts?
Running without the oxygen sensor the car will run in open loop (it runs off of known tables in the computer rather than taking input from o2's) so it ran okay, then you plugged it in so it's running in closed loop now. The best thing to do would be to use a scanner to get some live data and see if the oxygen sensors are switching properly, and indeed showing a reading. If you have exhaust leaks ahead of, or directly behind the oxygen sensors it could definitely contribute to running poorly, maybe a fouled plug, etc
