Ls1 coolant tubes
Old May 30, 2014 | 10:03 AM
  #61
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I really like that simple setup Conan posted. Good use of other GM parts
Old May 30, 2014 | 12:30 PM
  #62
conan's Avatar
Originally Posted by 427LS7HCI
Thanks guys...
Here's some finished pics if any one cares.
[IMG][/IMG]
[IMG][/IMG]
Old May 30, 2014 | 01:29 PM
  #63
CBM Motorsports's Avatar
Not sure how this setup will work. Is your coolant fill point above the top of the cross over lines? If the fill point is below them, there will be air trapped in there. Sure the lines should have coolant pumping through them but at the same time the front and rear of the heads are pushing water out. So you have two things pushing against each other and not flowing. Maybe that is why GM decided to get rid of the rear steam ports? Hope that makes sense. I will draw up a picture to explain better.
Old May 30, 2014 | 01:52 PM
  #64
Here is my wonderful picture. Again this is just a theory I have. In a perfect world, all the pressure will bleed out the front feed back to the radiator and all will be good. But this is my worst case thought.
Old May 31, 2014 | 07:42 PM
  #65
No Juice's Avatar
in for more.......
Old Jun 1, 2014 | 09:15 PM
  #66
Bama99z's Avatar
Well I finally got around to running mine today. The lone brass tee will be swaped out for a nice stainless one tomorrow.
Attached Thumbnails Ls1 coolant tubes-steam-tube-1-.jpg   Ls1 coolant tubes-steam-tube-2-.jpg   Ls1 coolant tubes-steam-tube-3-.jpg
Old Jun 4, 2014 | 11:25 PM
  #67
gMAG's Avatar
I took the same crossover tube as used on the front, w/steam tube, and used it on the rear.
The steam tube was cut (too close to firewall), somewhat, then flared, then capped. The crossover fits perfectly to the rear fittings...not as elaborate as the "all the way around" system, but works just fine.
Old Mar 27, 2015 | 04:22 PM
  #68
warriorpluto's Avatar
Originally Posted by conan
Here's what I'm doing with my steam ports this time around... The rear crossover tube is from a cadillac, GM part #12605716. The front cross over tube is from the ls6. I dont have any finished pics but I'm using the black braided fuel hose and have the 2 lines connected together with a stainless 1/4" Y fitting where it plumbs into the radiator.
Here's the rear cadillac crossover...
Here in the green square is the front ls6 crossover...
Have any finished pictures?
Old Mar 27, 2015 | 09:36 PM
  #69
conan's Avatar
Scroll up to the top of this page you missed them.
Old Mar 28, 2015 | 10:50 PM
  #70
Oh ok I see.I overlooked them. Where did you get your hoses and the little tee fitting?
Old Mar 28, 2015 | 11:43 PM
  #71
conan's Avatar
The stainless barbed Y fitting I got from this place http://www.chicompany.net/index.php?...ndex&cPath=287
The black braided hose I got from summit racing.
Old Apr 2, 2015 | 08:12 AM
  #72
Twinstang's Avatar
[/URL]
What's everybody's thought on this now I'm confused.
Old May 4, 2015 | 12:46 PM
  #73
A-man930's Avatar
Subscribing...
Old Jul 7, 2015 | 09:15 PM
  #74
dannyj661's Avatar
Hey Guys,
I have a ls1 gonna run a 76mm turbo try to get 800 plus rwh. I have the coolant lines that run basically all four ports together. Is that best, or just the two fronts one line and the rear two one line. it came factory with the back blocked off. my question is whats the best configuration tie the fronts together and the back together. L-Brown where did you get the nice fitting like that.
Old Jul 7, 2015 | 10:51 PM
  #75
Paul Bell's Avatar
That's MISTER MODERATOR
It's best to use four corner cooling. It doesn't really matter how you get them all tied together into the one return to the radiator.
All the coolant flows from the head corners towards the radiator.
