Breather Set
Old Oct 16, 2013 | 01:41 PM
L_Brown's Avatar
Default Breather Set
On an engine similar to this one. What would be the best breather set up. Any diagram would be great.
Old Oct 16, 2013 | 01:56 PM
L_Brown's Avatar
Default Breather Setup
I found this
Old Oct 17, 2013 | 09:37 PM
L_Brown's Avatar
Anyone?
Old Oct 18, 2013 | 06:51 PM
conan's Avatar
What valve covers and galley cover do you have ?
Old Oct 18, 2013 | 07:08 PM
L_Brown's Avatar
I will be running the valve covers like the engine pictured. They come with or with out an oil fill. I planned on one of each. I am going to run the Edlebrock lifter valley cover.
Old Oct 18, 2013 | 07:17 PM
L_Brown's Avatar
This is my engine build list, so far.
Not going to happen all at once but it will get done.
5.3 LS V8 - 04 AVALANCHE
PISTONS - Manley Platinum Pistons/Rings 592207c-8 (3.905 bore)
RODS- MANLEY H BEAM MAN-14051-8
ROD BEARINGS - CLEVITE 77 X 8 CB663P
MAIN BEARINGS - CLEVITE 77 MS2199P
CAM BEARINGS - CLEVITE 77 SH1814S
COIL RELOCATER KIT LS2 STYLE
#706 HEAD WORK GM 5.3 STAGE 2
GM PERFRORMANCE VALVE COVER 25534398
GM PERFRORMANCE VALVE COVER 25534399
EDELBROCK VALLEY COVER PLATE 7788
CRANE CAM - CUSTOM GRIND 144HR00220
CRANE LIFTERS 144536-16
GM PERFROMANCE INTAKE MANIFOLD 88958675
HOLLEY 750 CARB 510-0-76750RD
COMP CAMS PUSH RODS 7638-16
MSD PLUG WIRES 121-32079
MSD LS2 COIL SET 121-82878
MSD CONTROLLER 121-6010
MSD PROGRAMMER 121-7550
TUFF STUFF WATER PUMP TFF-1310A
FLUIDAMPR BALANCER 388-740111
HARLAND SHARP ROLLER ROCKERS SLS17
Old Oct 18, 2013 | 07:59 PM
conan's Avatar
Does that valley cover have a PCV tube or are you just going to vent the rocker covers ?
Here's what I run... No pcv and I just have the rocker covers vented to a big vented puke can from e bay...
Old Oct 18, 2013 | 09:09 PM
L_Brown's Avatar
No it does not, I am going to buy a catch can from a member on here
Old Oct 18, 2013 | 09:33 PM
1BAD98LS1's Avatar
I've Seen people vent from a billet oil fill cap with -AN fitting and have -AN lines run into a catch can just like Conan posted.
