Fast 102 Fitiment Questions
Good evening everyone, I have a few questions as I just ordered my new Fast 102 today. It will be ported and matched to my new heads. I was told that there are several fitiment issues associated with it. Please chime in with your comments.
1. Fuel Rail- I heard that the only fuel rail that will clear the intake is the LS3is that correct? If so does anyone know the correct P/N for it?
2. Map Sensor- I heard that some folks relocate it to the front of the intake due to clearence issues. If it is moved to the front you have to drill the intake to allow it to be installed there, as well as order an extension harness to relocate it. PROS/CONS? Does anyone have the P/N for the harness extension just in case I deceide to relocate? Where is the correct location that it is suppose to be relocated too? Pics would help out alot on this.
3. Injectors- I'm working on buying an almost new set of Siemens Deka 60lb/hr injectors from a good friend of mine for the set up. But he said that he doesnt think that they will work with the LS3 fuel rail. Why is that? I also heard that they would work so I dont really know. Looking for info from someone that has already figured this out. If you know what I need to make the injectors work please let me know.
4. Water Pump- I was also told that the stock LS1 intake had to be ground for clearance so that it would not hit the intake. Is there another one that could be used that will clear the intake, as I dont want it to bee too close and hit. I also prefer not to have to grind on the intake or water pump. Surely there is one out there that will clear.
5. Front/Rear Engine Coolant Pipe- Is there one that will clear the intake without bending or modifying? Do I need to block off the rear ones? I'm going with the LS6 valley pan if that matters.
Thanks In Advance,
Eric
Thanks In Advance,
Eric
Answer: No, The LS2 rail works with the FAST 102. Sorry I don't know the part #
Answer: It can go either in the front or the back. Either way you will have to drill the hole.
Answer: All LS injectors will work. LS1 injectors, you need the rail spacer kit or the correct FAST rails. LS2 injectors perfect for LS2 rail. LS3 injectors need injector spacer or correct FAST rail
Answer: Depends on your water pump. The later style would require none or minor grinding.
Answer: Use LS3 front coolant pipe. LS6 will have to be bent and looks like crap.
The LS2 GTO water pump that has the same cone shape pulley on the front like the LS1 fits perfect without issue. Ask me how I know
lol
If you search you may come across Bayers thread, I had the issue with my new 102 Fast & found out from discussions with my then workshop about what to do & we realised that a 'I am in NZ' Monaro 'GTO' LS2 pump would clear the Fast 102. The rest is history
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
Check clearance by the Oil Pressure switch ! When I installed mine in car, did not know it but FAST 102 was rubbing OIl press sensor. When I dropped engine out of car, oil press switch just fell apart. I filed off the back around the oil press switch. good clearance now.
