v6 to lt1 swap questions
Old Nov 2, 2013 | 06:03 PM
4thgenbeast's Avatar
Default v6 to lt1 swap questions
I recently bought a 2001 v6 camaro with a blown motor I bought an lt1 and am currently doing the swap I was wondering if I needed anything other than the engine tranny driveshaft and rearend I am also getting the computer and pcm and fuel pump I was also wondering if I should twin turbo it or get a supercharger for more rwhp and does anyone have any chip/programmer info?
Old Nov 2, 2013 | 09:01 PM
Burken01's Avatar
First I would go read in the swaps/ hybrid section, then I would look in the FI section and read the turbo stickies to see everything you will need to do a turbo/S-charger build..
Ill be honest to do all that is one big long project..
But it is doable if your doing all your own work.
Old Nov 4, 2013 | 06:37 AM
Paul Bell's Avatar
That's MISTER MODERATOR
4thgen, welcome to LS1tech! SEARCH will be your best friend around here.
Your question might be best asked in the LT1/4 section:
https://ls1tech.com/forums/lt1-lt4-modifications-31/
I'll tell you here it's waayy easier to find a V8 car to begin with-and look for the later LS1 cars.
