idle issues, iac??
Old Nov 4, 2013 | 12:34 AM
Zlow28's Avatar
Default idle issues, iac??
My car has been having an idle issue which seems to be getting worse. It has similar symptoms of a vacuum leak, but i have checked for vacuum leaks 3 times and nothing shows up. Around 75% of the time, when i come to a stop, the idle sticks to about 1400rpms and drop to about 1000 when it hits a complete stop. The idle also surges between 1000-1200rpms when idling at a stop.
My car is stock internals, ls6 intake, ls6 valley cover, EGR!, AIR!, new eval purge solenoid, and about 105k miles.
Ive checked for vacuums many times and can't find any. I also notice that when i plug the small hole in the throttle body blade, then the problem stops and idles perfectly.
Also, i noticed that whenever i unplug the IAC while the car is in idle, the rpms shoot up to about 2k and stay there. Mostly everywhere i read, the opposite happens. Has anyone had this problem before? or any ideas on what to do?
Old Nov 4, 2013 | 12:42 AM
Zlow28's Avatar
heres also another funny thing that might be related with the IAC. Whenever i turn the steering wheel all the way to any side to active power steering, the idle also goes back to normal. I read somewhere that the IAC responds with certain electric devices like lights and power steering.
Old Nov 4, 2013 | 09:10 PM
Zlow28's Avatar
anyone? do i need to replace the IAC valve?
Old Nov 4, 2013 | 10:22 PM
Zlow28's Avatar
will i be ok if i solder the throttle body blade hole shut?
That seemed to stop the problem last night.
Old Nov 5, 2013 | 07:04 AM
Streetlegal?'s Avatar
I have the same issue but I can't seem to find the problem. Ended up just putting electrical tape over my TB hole and it fixed it for now. I know it's a band aid fix but I needed to get the car home. Another guy around here had to do the same thing. We're still trying to figure out what it is.
Old Nov 5, 2013 | 07:51 AM
02BlkZ28's Avatar
Question is how are you checking for leaks? Did you hook it up to a smoke machine? Cause i had a massive intake leak & it didnt show until i pumped smoke into the intake. Sounds like a leak. I dont think that lil hole is the problem or the car would of done it its hole entire life.
Old Nov 5, 2013 | 08:22 AM
mjs1012's Avatar
I had a similar issue earlier this year and I adjusted my idle in hp tuners and it leveled out. I put in new iac/tps and it did nothing before.
Old Nov 5, 2013 | 10:03 AM
Zlow28's Avatar
Keep me posted if you find a fix. I also have tape covering the tb hole, but i don't drive it a lot in fear of it being sucked in.
I used carb cleaner, and sprayed it in all the areas i could think of where there could be a leak. I couldn't find anything.
Was your car modded when this happened? Ive also heard it could be in the tune. I don't have any way to tune my car though. Might have to invest in tuning software.
Old Nov 5, 2013 | 10:38 AM
mjs1012's Avatar
Yes it was modded. Last fall before I drove the car it was fine then in the spring it was doing it before I put on a ported TB. I checked and replaced vacuum hoses, intakes/tb gaskets and replaced the iac/tps and it didint help.
All I did was adjust the idle to be steady and it fixed it.
Old Nov 5, 2013 | 10:49 AM
Zlow28's Avatar
Thanks, ill try to get ahold of a tuner again and see what we can do.
