Things to do first before adding power?
Old Nov 7, 2013 | 08:19 PM
M4N14C's Avatar
Default Things to do first before adding power?
So in the past few months I've owned my car, I've spent it fixing little things, upgrading the sound system and making sure it's running 100%. Now I want to start adding power. I'm saving up for my first big purchase, a full blown Kooks True Duals exhaust system. But before I start building my motor, are there any supporting mods I should so first? All I have done so far performance-wise is a lid. Rear end, clutch, and internals are all stock. I plan on eventually making 450-500rwhp all motor.
So should I spend my money now on upgrading drive train components or just go with bolt on power? Plan on mostly doing autocross and road racing, maybe hitting the strip a couple of times just to see what I run.
Old Nov 7, 2013 | 09:41 PM
Majestic9C1's Avatar
Suspension and Tires.... All that power and no where to plant it is useless..
Lower Control Arms
Panhard Bar
Poly sway bar links and bushings
just a few to get started
Old Nov 8, 2013 | 12:05 AM
fruitsalad's Avatar
For your rr/ax goals I would suggest getting a set of Konis and Stranos to start, then adding better sway bars, Watts link, decoupled torque arm, etc., plus a set of nice wide wheels and R compounds. Stay with the 10 bolt rear for rr/ax; it'll save you weight, money, and time. Do a Tick master. If you're serious about it, Turn One PS pump, oil cooler, and a real power steering cooler too. Then while you're in the engine changing stuff up to make power, don't forget a ported LS6 oil pump, improved windage tray and/or oil pan, and the usual pushrods/springs/rockers. Then do some V brakes.
With all that you should have a really solid foundation to make lots of power with.
As for which one you should do first... that's up to you if you're ready to start HPDEs and autocrosses right now, do the suspension & brake work first. I would probably do shocks and springs first either way, then maybe cam, valvetrain, and oiling, then the more in depth suspension bits, then on to more power.
Old Nov 8, 2013 | 12:12 PM
M4N14C's Avatar
Lower Control Arms
Panhard Bar
Already got a set of 275 G-Force T/A KDW's. Pretty good in the dry but in the wet it's like I'm on ice
Good stuff. But is my stock clutch good for now? Also since the Kooks duals go over the axle, will I still have room for a watts link?
Old Nov 8, 2013 | 08:58 PM
sscamaroburn02's Avatar
Stock clutch will suffice for now if u know how to drive and are careful. May upgrade to a tick master which would help a lot. I'm still running my stock clutch and 10 bolt on 450 whp. I just make sure I hit the gears solid and don't slip it. Going on 4 years now
Sent from my HTC One VX using IB AutoGroup
Old Nov 8, 2013 | 09:25 PM
BrntWS6's Avatar
Do shocks / springs / sways before any other suspension on your car. Those are the most important components to a well handling car. Plan for a clutch...450rwhp on the stock clutch is definitely not the norm...mine was useless with 420rwhp. Spend the extra $100 and go with a monster or TDP clutch. An LS7 is a waste of money IMO. At that power level a new rear can usually wait if yours is healthy.
Old Nov 8, 2013 | 09:30 PM
Agree suspension first. Stock clutch will last if your careful until you can save up
Old Nov 9, 2013 | 12:30 AM
fruitsalad's Avatar
Almost 100% positive that you can run a watts with Kooks TDs. As for clutch, obviously you're going to want a new one without the self adjusting pressure plate, but for now at your power level I wouldn't say it's the weak point yet. Just prepare for it some time in the future.
 Michael S. Palmer
Old Nov 9, 2013 | 10:10 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I can't believe a stock clutch is holding at 450. I smoked the HELL out of mine on the dyno when I hit 451. Yeah it drove, but I was missing a lot of topend. I didn't find THAT out until I put in the monster. I was missing a lot of power I didn't even realize.
When that clutch DOES come out, I'd really like to see pics of it.
Old Nov 9, 2013 | 10:27 AM
JakeFusion's Avatar
Super Hulk Smash
I would do this (order from Sam Strano):
Strano Performanace SP141 Lowering Springs
Strano Performance 35/22mm Hollow Sway Bars
Koni 4/4 Sport Shocks
Best Brakes Signature Series Rotors
Hawk HPS Pads
Techna-fit Stainless Steel Brake Line Kit
About $2100 shipped to you. I wouldn't worry with the other stuff. That's more for drag racing and might hurt your handling. Eventually the Watts link is what you'll want and it should work with the Kooks. It's $650 from Strano.
I'd keep the stock 10-bolt. I wouldn't even mess with the gears yet.
Get a cam that makes power under the curve and works with stock gears. Tick SNS Stage 2 227/234 111+2 with Mild lobes for example would work. I'd also just send the stock heads off to be ported by AI or TEA. No need to try for 500rwhp. That won't make you faster in AX/RR. Just get the power up some. Work on building a lightweight valvetrain that will handle 4000+RPM. It's a different then a drag build. Easy lobes, bigger pushrods, and lightweight valves = key.
I'd get a new clutch with lighter flywheel. Monster Stage 1 + 18lbs Aluminum Flywheel. Weight is your enemy here. Or you can spend some big money on an RPS Dual Carbon Lite clutch. It's like 32lbs total. And inertia is much smaller, since the discs are much smaller on a dual disc clutch.
Old Nov 9, 2013 | 09:06 PM
M4N14C's Avatar
Mis-shifted just a couple times, and those were within the first week I bought my car. Hope with tick + MGW shifter my clutch will last to at least 400rwhp.
Hawk HPS Pads
My to-do list for 2014
As for weight reduction, I'd like to get down to at least 3200ish with me in it(160lbs). Is that possible without tearing out the interior and keeping daily drivability?
Old Nov 14, 2013 | 10:15 AM
Sure no problem. I've been surprised as well that it's held up as long as it has. My top end is there and runs to about 6400 rpms. The only thing is on a extremely hot day the clutch gets stuck on floor at end of 4th on wot sometimes.
Old Nov 14, 2013 | 10:20 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
Our watts link will work with true duals and is $625. Give us a call if you have some questions!!
Old Nov 16, 2013 | 10:08 PM
joecar's Avatar
The best performance upgrade is to replace old worn out chassis rubber components with new ones (i.e. motor/trans mounts, suspension bushings, etc).
